Style swap is not working
  • March 20, 2023
  • 623 views
Remy_Guestereguy
Hello,
Since last update, I’ve noticed that I can’t swap color styles on an element.
Selecting a new color style doesn’t modify the existing one.
It only works if I unlink the selected style and then select the new one.
Is it a known issue?
Best regards,
Rémy
Gayani_S
  • March 21, 2023
Hi Remy, I’d recommend contacting support and providing them with links to your library and subscribed files. Support can investigate here what is causing this.
Diego16
  • May 23, 2023
I have the exact same problem here
Do they gave you any solution?
Remy_Guestereguy
Absolutely not, never received an answer and it resolved itself some updates later.
