Auto-Layout issue with Text
  • May 13, 2024
  • 601 views
Hello everybody,
I have a big issue Auto-layout with my text. When I start to create a button, it doesn’t fit well when I press shift + A. But in another document it fits perfectly automatically. What can I do to fix it please, I already check every forum and videos on Youtube, nothing closed or similar to solve my issue.
Here my issue :
Thank you very much.
Best answer by Junko3
Hi @Gaveen, Thanks for reaching out and taking the time to explore potential solutions. I really appreciate your effort.
I’m not completely certain what might be causing the issue without seeing the actual file. However, one possibility could be related to the resizing settings of the auto layout frames.
I noticed that the Auto Layout frame ‘Frame 1’ might not be adjusting to the height of the text button.
In this case, could you try selecting the auto layout frame from the Layers panel and setting the vertical resizing to ‘Hug contents’ to see if it makes any difference?
You can learn more about resizing in auto layout frames from here: Explore auto layout properties - Resizing
I hope this helps! If there’s anything I misunderstood, please let us know.
We also welcome any additional insights or suggestions from our community, so if you have any, please feel free to share them here.
  • Figmate
  • May 15, 2024
  • May 15, 2024
Hi Junko, it seems fixed. Thank you very much !!
