Creating swap property for nested component containing text not working
  • December 21, 2023
  • 232 views
I have a button icon component set with different button (and icon) sizes. I want to create icon swap in my properties so it is easy to switch it using panel on the right.
The icon set we are using is fontawesome icon font (not SVG file).
When I create icon swap property and apply it to all the icon sizes in the component set, all my icons change to the same size. Ie I cannot have different sizing of icons attached to the same property.
Is anyone having the same issue and how did you resolve it? I have a suspicion the issue stems from using live font in icon set rather than SVG file. Note: converting icons to SVG is not the option for us.
Gayani_S
  • December 22, 2023
Hey Ida, if I have understood your issue correctly this is a longstanding feature limitation. The way it works today, is that the size of a nested instance will always stay the same no matter what you swap. In other words, when you swap a nested instance, it will take the size of the original nested instance that was there.
