Figma checkbox conditions
  • April 18, 2024
  • 503 views
Problem:
I’m having trouble implementing a “Select All” checkbox that controls the state (checked or unchecked) of multiple other checkboxes.
Desired Behavior:
  • Clicking the “Select All” checkbox should:
    • Check all other checkboxes if it’s currently unchecked.
    • Uncheck all other checkboxes if it’s currently checked.
Technical Details:
  • I’m using checkboxes with three possible states: “Checked,” “Unchecked,” and “Mixed”.
Question:
What’s the simplest way to achieve this behavior?
ksn
  • April 18, 2024
Hey @Stav_Lifman – this is a bit of an older topic, but does the conversation that happened here get the behavior you’re looking for? Select all Checkbox
There’s an example file that helps visualize things as well.
