Button to different variants
  • January 30, 2024
  • 5 replies
  • 662 views
trying to click the buttons to change the right side image to their number i have put them in a component to switch them in variants, but it doesnt work stays on image 1
Capture
Best answer by Geoffrey_Menissier
I think this one is exactly what you are trying to achieve :
Raphael_M
  • January 30, 2024
Hi, Marc.
Is it possible for you to share the file so I can check it?
Thanks!
  • January 30, 2024
sure raphael here’s the link
Figma – 30 Jan 24
Raphael_M
  • January 30, 2024
Hi, Marc.
Upon checking your file, you set all the scroll to to the same frame.
You need to set the buttons to the specific frame they should go to inside the frame.
btn 1 should scroll to Frame 1, btn2 to Frame 2…
I put a sample on your drafts. I did the same implementation you are trying to do among the many ways of doing a carousel.
If you have other questions, just let me know.
Thanks!
Geoffrey_Menissier
  • January 30, 2024
Thank you so much its clearer now
