Editing multiple variables in one batch
  • February 29, 2024
  • 5 replies
  • 2089 views
Hello friendly people,
I’ve gotten myself into a rather uncomfortable situation regarding my variable set up, the issue at hand:
I have added lots of color variables but always duplicated the previous group structure. All of my variables have now these properties:
I am wondering, is there a way / or plugin where I can take a set of variables and edit their properties? In my example the color scoping should be entirely deselected and the code syntax should be just the default for now. This I want to apply to 60 variables in one batch. Is that possible?
There is probably an easy solution to this that I am missing, but I couldn’t find anything in the forum 😦
As an interesting addition to that problem: Is it possible to generate code syntax abbreviations for new variables in a pre-defined way? So say my syntax needs to look like this: ${Colors. Blue[100]} and a subsequent shade would just be ${Colors.Blue[200]} etc. Is this possible in Figma? Is there a Plugin for that?
Thank you very much in advance!
Best Sam
Best answer by Junko3
Hi @Samu1, Thank you for reaching out! I understand how challenging it can be to update 60 variables one by one.
Rest assured, you can edit variables in bulk in a collection by selecting multiple variables by using short cut:
  • Mac: Hold ⌘ Command / Control and click to select individual variables
  • Windows: Hold Shift and click to select a range of variables
For more detailed instructions, please refer to the “Edit variables in bulk” section in this guide: Create and manage variables
I’ll share your question regarding pre-defined code syntax internally to explore any possible solutions. I will provide an update once I have more information on this.
Also, Feel free to explore our community on your own. While I haven’t found an exact match yet, you might find helpful resources here: Plugin results for variable code syntax
I hope it helps! If I overlook something, please let us know. Also, if anyone in our community has suggestions or insights, please feel free to jump in!
Thank you,
  • Figmate
  • March 4, 2024
Thank you,
  • Figmate
  • March 6, 2024
Hey @Samu1, For your code syntax question, I reached out to our internal team, and unfortunately, we currently do not have a prewritten plugin for this specific purpose. However, any user can create their own custom code syntax generation using the plugin API.
I hope this information is helpful to you! Also, we welcome input from other community members, so please feel free to share your insight here.
  • March 6, 2024
Hey Junko,
first of all, thank you for your first suggestion. I knew that I could make a selection but didn’t see that I needed to activate a dedicated “edit variable” menu, so that cleared my confusion up!
Regarding the second request: Also thanks for checking in with your internal team on that one. I am a developer first and foremost and already thought about making a plugin for that as it’s a very frequent task for me (in my workflow at least). I am gonna post the link to the plugin here once I have made it 🙂
Best Sam
jeremy.sallee
Hi @Samu1, did you write a plugin for this? I am sure it would be extremely useful for the community.
  • July 2, 2024
Hey Jeremy,
sorry for the late reply,
I was not yet able to find time to do so, it’s on my to-do list 🙂
I have to first migrate a design system for my company with all sorts of token translations and gather learnings along the way to make a somewhat good judgment on how to approach this from a user perspective.
As soon as I have made the plugin, Ill post it here 🙂
Best Sam
