Relay for Figma plugin : Preview of generated code is correct but different in used in Activity
Ragesh_Antony
I am currently testing “Relay for Figma”, a tool that exports Figma designs to jetpack compose
I have a problem
After importing the Figma design and generating the compose code,
The preview when previewing the generate compose code is fine
But when I was trying to use it, that is in Activity then the preview is completely distorted
And the same issue is happening when trying to run in device also
When this issue is happening ?
Figma project : https://www.figma.com/file/WynufomfvkuGjpw4BQjucw/Login-UI-Design-(Community)?type=design&node-id=0%3A1&mode=design&t=PajYAYOD77PAUECC-1
