How can I show the variant count with add + icon with the component as screenshot?
  • May 30, 2023
  • 10 replies
  • 698 views
Please take a look above screenshot, there is a button, and a count appears when selecting the component.
Do you know if this default is from Figma?
Best answer by tank666
I’m sorry but your code is not complete enough to test the functionality.
Here is a code snippet for creating components and combining them as variants.
let arr = [],
	x = 0;
for (let i = 0; i < 8; i++) {
	const component = figma.createComponent();
	component.name = 'Value ' + (i + 1);
	component.fills = [{
		type: 'SOLID',
		color: {
			r: Math.random(),
			g: Math.random(),
			b: Math.random()
	if (i > 0) {
		x += component.width + 20;
		component.x = x
	arr.push(component)
figma.combineAsVariants(arr, figma.currentPage)
tank666
  • May 30, 2023
Your screenshot shows a ComponentSetNode. When it is selected, Figma displays in the UI the total number of variants (ComponentNodes) and a + (add variant) button. So, you need to create a component set using the combineAsVariants method, as I wrote to you in another topic.
Can you give me a small piece of code for a demo? I am new here. It would big help for me. I have used loop to create button and appending in parentComponentNode.
const buttonInstance = figma.createComponent();
  buttonInstance.resizeWithoutConstraints(parentWidth, parentHeight);
  let child = [];
  let i = 0;
  for (const variant of buttonVariants) {
    const child = figma.createComponent();
    console.log(i);
    buttonInstance.name='Button Variants'
    console.log(current_x, (buttonWidth * Math.floor(i / rowCount)), (columnSpacing * Math.floor(i / rowCount)),'for x pos')
    const button_x = current_x + (buttonWidth * Math.floor(i / rowCount)) + (columnSpacing * Math.floor(i / rowCount));
    const button_y = current_y + (buttonHeight * (i % rowCount)) + (rowSpacing * (i % rowCount));
    console.log(current_y, (buttonHeight * (i % rowCount)), (rowSpacing * (i % rowCount)), 'Y pos', button_y);
    // Calculate the button position
    const variantComponent = figma.createFrame();
    variantComponent.resizeWithoutConstraints(75, 40); // Set the size of the button
    variantComponent.name = variant.name;
    if(variant.name.indexOf('Ghost') === -1 ){
      if(variant.name.indexOf('Border') > -1){
        variantComponent.fills = [];
        variantComponent.strokes = [{ type: 'SOLID', color: variant.style.borderColor, opacity: 1 }];
      }else{
        variantComponent.fills = [{type: 'SOLID', color: variant.style.backgroundColor}]
    }else{
      variantComponent.strokes = [];
    variantComponent.cornerRadius = 5; // Set the border radius
    variantComponent.primaryAxisAlignItems = 'CENTER';
    variantComponent.counterAxisAlignItems = 'CENTER';
    // Create the text node
    const buttonText = figma.createText();
    buttonText.characters = 'Label'; // Set the text content
    buttonText.fontSize = 16; // Set the font size
    // if(variant.name.indexOf('Ghost') === -1 ){
      buttonText.fills = [{ type: 'SOLID', color: variant.style.textColor }];
    buttonText.textAlignHorizontal = 'CENTER'; // Align the text horizontally
    buttonText.textAlignVertical = 'CENTER'; // Align the text
    if(variant.name.indexOf('Disabled') > -1){
      buttonText.opacity = 0.5;
    buttonText.resize(variantComponent.width, variantComponent.height);
    // figma.currentPage.appendChild(variantComponent);
    variantComponent.appendChild(buttonText);
    variantComponent.x = button_x;
    variantComponent.y = button_y;
    buttonInstance.appendChild(variantComponent);
    i++;
  figma.combineAsVariants([buttonInstance], figma.currentPage);
This is my code I have created button with frame component
tank666
  • May 30, 2023
let arr = [],
	x = 0;
		type: 'SOLID',
		color: {
			r: Math.random(),
			g: Math.random(),
			b: Math.random()
	if (i > 0) {
		component.x = x
	arr.push(component)
Thanks for info, But how can we arrange like screenshot and give name to the main combine component?
tank666
  • May 30, 2023
const componentSet = figma.combineAsVariants(arr, figma.currentPage);
componentSet.name = 'Component Set Name'
Write the necessary conditions where you will change the X, Y coordinates.
Thank you! very helpful
Thanks
const buttonWidth = 75;
  const buttonHeight = 40;
  const columnSpacing = 25;
  const rowSpacing = 60;
  const spacingTop = 20; // Adjust the top spacing as desired
  const spacingLeft = 20; // Adjust the left spacing as desired
  const spacingRight = 20; // Adjust the right spacing as desired
  const spacingBottom = 20; // Adjust the bottom spacing as desired
  const buttonCount = buttonVariants.length;
  const columnCount = Math.ceil(buttonCount / 4); // Assuming each column contains four buttons
  const rowCount = Math.min(buttonCount, 4); // Assuming a maximum of four rows
  const parentWidth = (buttonWidth * columnCount) + (columnSpacing * (columnCount - 1))  + spacingLeft + spacingRight
  const parentHeight = (buttonHeight * rowCount) + (rowSpacing * (rowCount - 1)) + spacingTop + spacingBottom;
  let arr = [],
	x = 0;
  let current_x = spacingLeft;
  let current_y = spacingTop;
for (let i = 0; i < buttonVariants.length; i++) {
    component.name = buttonVariants[i].name;
      type: 'SOLID',
      color: buttonVariants[i].style.backgroundColor
    component.layoutMode = 'VERTICAL'
    component.cornerRadius = 5; // Set the border radius
    component.primaryAxisAlignItems = 'CENTER';
    component.counterAxisAlignItems = 'CENTER';
    component.counterAxisSizingMode = 'AUTO';
    component.primaryAxisSizingMode = 'AUTO';
    component.resizeWithoutConstraints(75, 40); // Set the size of the button
    buttonText.fills = [{ type: 'SOLID', color: buttonVariants[0].style.textColor }];
    buttonText.resize(component.width, component.height);
    if(i>0){
      component.x = button_x;
      component.y = button_y;
    component.appendChild(buttonText);
	arr.push(component)
const mainCom = figma.combineAsVariants(arr, figma.currentPage)
mainCom.name = "Buttons";
mainCom.resizeWithoutConstraints(parentWidth, parentHeight)
Thanks for your help, But 1 issue is not taking x position for first component componentNode.
See the screenshot button touches from left and top.
tank666
  • May 30, 2023
Change the X, Y coordinates for each child in the component set.
How can we do it? If i removing the condition I>0 then the all button’s x and y not work.
Done. I got it Thanks for all your Help. You are amazing guy!
