Magician access key
  • July 29, 2024
  • 11 replies
  • 7641 views
Chris_Jones
I am trying to use the plugin ‘Magician’ in Figma, but when I do, it asks for an access code. However, when I click ‘Start Free Trial,’ it just loops back to Figma. What am I missing?
Best answer by KennLucas
I never saw the plugin before. But you would do better through the plugin page for support than through the Figma support forum.
I found this link.
Hope it helps!
support.diagram.com
KennLucas
  • July 29, 2024
I found this link.
Hope it helps!
support.diagram.com
Kay13
  • August 14, 2024
Same for me, I assume they’ve maxed out free trial users and haven’t built a decent web journey.
Brian_Saunders
Since Diagram was acquired by Figma I’m pretty sure all their plugins are no longer supported.
rohan_bokadiya
Why is it marked as the solution? I can’t use this plugin due to the access code pop-up.
KennLucas
  • September 25, 2024
It WAS a proper solution where you go to the link provided which was the support page for the plugin. Not trying to access some other company support through Figma software. There is no access code needed to go to a website.
Or at least it WAS. Unfortunately that has changed as @Brian_Saunders stated, there were changes at Diagram and all of those support links are now gone.
This was a proper solution at the time. Circumstances have changed.
The plugin is no longer available.
Apologies that time has passed and things change in business and in life.
NYC2024
  • October 15, 2024
It does not work for me as well
Venkatprabhu
  • April 10, 2025
Same thing is happening for me
Fey Chen
  • April 14, 2025
Same thing is happening for me today, it is not work now.
Does any one can solve it for me, thanks!
Whitelabel_IQ
Henry Zhu
  • June 7, 2025
Magician’s parent company Diagram has been aquired by Figma. So it likely we see its feature being integrated into the upcoming Figma AI. So the plugin is no longer avaliable.
Still, they really should put up a notification on the plugin page at least.
donini
  • July 23, 2025
And is there any alternative plugin to use now? Any suggestions?
