Prototype - Fit Width not working on newer Macbook Air 13.6 inch
  • March 8, 2024
  • 7 replies
  • 594 views
Ben_Hacking
Have been searching for solutions to this but cannot find any. Since moving to a newer Macbook Air 13.6 inch, fit width no longer actually fits width, nor does fill screen or fit to screen.
I have a black border all around the prototype regardless of which setting I use for this.
Any solutions or has anyone else had this issue?
Using Chrome, using the web version of Figma, only change has been that my laptop has a newer screen size than before.
Thanks
  • March 11, 2024
Hey there,
Thank you for your post. Just to clarify, are you not selecting any device? The “Fit width” option is only available if you are using a custom frame size without selecting a device. You can find more information here: https://help.figma.com/hc/en-us/articles/360040318013-Play-your-prototypes#h_01HER6XXFTAK565E14WGYEM4T4
If this issue persists, please don’t hesitate to reach out to our support team here: https://help.figma.com/hc/en-us/requests/new.
Thanks!
Toku
  • May 16, 2024
I have this issue also. It’s very annoying.
I cannot adjust the size of the frame or group for anything. On Windows, I can adjust with a drag of the mouse on the selection box OR adjusting with the W on the Design panel.
However, on a Mac if I use the selection box it does nothing and if I use W on the Design panel, my cursor locks up with a double arrow cursor that stays on the screen.
  • August 20, 2024
Could you share a screen recording so we can understand what’s happening on your Mac environment? I can’t reproduce the behavior on my end.
Toku
Fidel_Carrera
  • February 11, 2025
Has anyone figured out a solution to this problem? At my company, we launch a lot of user tests every week and desktop prototypes will no longer fit the user’s screen despite selecting “fit width” as the scaling option. For example, if the design is 1440 and we have a user with a 4k monitor, they will get massive black bars on each side. When running our prototypes through Axure, we never have this issue as the Axure scaling will properly stretch the prototype to fill the user’s screen. Any ideas how to resolve this issue in Figma? Here is a partial screenshot to show the issue (I did not want to reveal all of the contents since it is from an unreleased design). The design being used also has a properly defined height which should make scaling work even better.
Adam_J
  • February 18, 2025
It's a big issue for me, too. I think Figma destroyed these features while they were “fixing things that aren’t broken last time” It worked perfectly well some time ago. When are you guys going to fix this?
Adam_J
  • February 18, 2025
red is the frame - when fit width
Oh, brilliant move by the devs! They totally didn’t just remove scaling when the frame is smaller than your screen resolution by accident. No, no—this was obviously a strategic decision to make Figma’s UX just that much worse, so users have something to complain about. Genius! And if you dare to scale your frame? Oh, of course! You now have to manually make it bigger than your screen resolution. Because that’s exactly what every designer dreams of—extra steps for no reason. Bravo! 👏
