setProperties error
  • March 26, 2023
  • 4 replies
  • 949 views
Sometimes when I generate and set new props randomly with API, I’m getting this error.
which is strange because the instance props I want to replace, and new props, are the same 🤔
Best answer by tank666
Thanks for the detailed answer.
The error occurs because your component set is missing variants:
  • Size=small, Radius=on, Rotate=on;
  • Size=medium, Radius=on, Rotate=on;
  • Size=big, Radius=on, Rotate=on.
tank666
  • March 26, 2023
Please add steps to reproduce the bug. Also tell if all required components (variants) exist in the component set? Can you add a link to the test file and sample code?
  • March 26, 2023
@tank666 sure
  1. Open this file https://www.figma.com/file/2iQtWRfyqEOZo0udal3lqD/Test-file?node-id=0%3A1&t=HZ7z7PAmo0oLygXl-1
  2. Select the Component Awesome instance
  3. Run Scripter plugin
  4. Paste this code
const instanceVariant = figma.currentPage.selection[0] as InstanceNode
const sortProperties = (arr: string[]) => {
  const props = {};
  arr.forEach((str) => {
    str.split(",").forEach((pair) => {
      const [prop, value] = pair.trim().split("=");
      if (!props[prop]) {
        props[prop] = [];
      if (!props[prop].includes(value)) {
        props[prop].push(value);
  Object.keys(props).forEach((key) => {
    props[key].sort();
  return props;
function getRandomValues(obj) {
  const result = {};
  for (const prop in obj) {
    const values = obj[prop];
    const randomIndex = Math.floor(Math.random() * values.length);
    result[prop] = values[randomIndex];
  return result;
const allVariantsNamesArr = instanceVariant.mainComponent.parent.children.map(
	(child) => child.name
const sortedVariants = sortProperties(allVariantsNamesArr)
const randomProps = getRandomValues(sortedVariants)
instanceVariant.setProperties(randomProps)
// console.log(randomProps)
  1. Start to click on Run button
some “runs” will be successful, but some not.
tank666
  • March 26, 2023
  • March 26, 2023
You’re right, I didn’t think about that 🫠 Thanks for your help!
