Export SVG icon problem
  • July 22, 2024
  • 9 replies
  • 2113 views
Maxence
When devs try to export this svg icon, it doesn’t show the fill of the books inside the square…
Library
To made the shape of the books, i made a “substract selection” on one of them, I duplicate de shape and flat all of them to made a vector shape.
Thanks for your help 🙂
  • July 22, 2024
It’s possible that fill settings of the vector are incorrect. Try to use File Rule Editor Plugin to correct it.
Maxence
  • July 22, 2024
We’ve tried but it still doesn’t work 😕
  • July 22, 2024
Can you share exported vector here?
Maxence
  • July 22, 2024
I can’t share an svg format here, but here you can find a Figma file with the icon.
  • July 22, 2024
I see that the fill is still using even-odd rule, which may be the problem I mentioned earlier.
Export icon from this file and tell me if the problem is still there.
Maxence
  • July 22, 2024
I tried to export the icon from your file but the problem is still here…
  • July 22, 2024
Can you try again? I merged box object with books, maybe that will somehow help.
Maxence
  • July 22, 2024
The problem is still here… But when we export the icon with Sketch the problem is corrected so we take this alternative today. I don’t know if the problem comes from the Figma export 😕
KennLucas
  • July 22, 2024
This is likely because there is not a vector fill in the icon. Without this, there is nothing to export.
See this image. I added a vector fill layer.
This exports as you wish.
