Issue with smart animate in Autolayout
  • October 11, 2023
  • 409 views
Carry_the_carrot
Hello! I am having trouble with components that I want to smart animate.
Example: one button that grows while hovering on it. If I choose to smart animate it, then the page will reset the scroll position to the top.
The little box for “Reset scroll position” in the interaction is unticked. This doesn’t happen when I select “Instant” instead. It’s quite troublesome because the only thing I can really smart animate inside of my prototypes are things that don’t change the size in the y axis (I can make a button grow horizontally only, or change the opacity, colours, etc.). Any clues how this cloud be solved? Am I doing anything wrong?
Edit: All the frames in my prototypes were created with Autolayout.
Best answer by Ryan_52
Hi @Carry_the_carrot thank you for reporting this. It looks like you are experiencing a bug which our engineering team is actively investigating to determine its root cause and working towards a solution. At this time, the only workaround would be to use “instant” instead of “smart animate”.
Ryan_52
  • Technical Quality Specialist
  • October 20, 2023
Caio_Comporte
  • February 24, 2025
Hey ​@Ryan_52. It looks like this still happens even after almost an year and half. Where can I track the engineering team progress on this?
Autolayout is a key feature of any good designs and smart animate is a key feature of any good prototypes. It’s a shame we can’t have both working together...
