How to add a new component to an existing component
  • January 21, 2024
  • 5 replies
  • 4720 views
Trilby_Gustafson
I have several larger component cards I created and now I need to add a new field to it that is also a component itself but every time I try to add the new component frame to the existing component frame it will not allow me to do so. I even try to drop it in using the layers panel and that doesn’t work. I want to keep the new smaller component separate because I want to add this field to several different larger component cards so that I can update just the small component and it updates across multiple component cards. Is this possible?
Raphael_M
  • January 22, 2024
Hi, Trilby. Have you checked if you’re dropping the new component to an instance or in the main component?
Trilby_Gustafson
It’s to the main component
Raphael_M
  • January 22, 2024
That is weird. Unless you are dropping the main component inside another main component. Are you dropping an instance of the new component inside the main component?
  • You can only add things inside the main component and not on the instance.
  • You can’t add the main component inside another main component. But, you can add its instances inside another main component.
Trilby_Gustafson
That’s really helpful information. I just tried a few different ways to create an instance of my main component and it seems like the issue is when I copy/paste the main component it isn’t creating an instance but a whole new main component-so while I thought I was trying to add an instance I wasn’t. I’ve found that either I need to just duplicate the main component instead or use another method to create an instance and then I can place it in the other main component I’m trying to add it to.
Nitesh_Agrawal
@Trilby_Gustafson , Can you please let me know how did you achieve it?
I have a main component set that is made of 5 instance of different component. Now, I want to add a new component/instance instance inside my main component but I am unable to do it. Please help.
