Get selected parameters before submitting to on run
  • February 2, 2023
  • 492 views
Brian1
Does anyone know of a way to get access to selected parameter inputs before submitting the function on ‘run’?
I can see the parameters after it is submitted, but not before…
I’m experimenting with accepting parameters on input (read more here) and it seems there isn’t a way to do this. This would help with filtering or suggesting different inputs based on previous responses.
Thanks!
Best answer by tank666
figma.parameters.on(
  'input',
  ({ parameters, key, query, result }) => {
    switch (key) {
      case 'parameter1':
        result.setSuggestions([query]);
        break;
      case 'parameter2':
        if (parameters['parameter1'] === something) {
          // do something
        else {
          // do something else
        break;
      default:
        return
tank666
  • February 3, 2023
  'input',
    switch (key) {
      case 'parameter1':
        break;
      case 'parameter2':
          // do something
        else {
        break;
      default:
        return
Brian1
  • February 17, 2023
This works thanks for your help I appreciate it.
