Variables are unavailable
  • March 12, 2024
  • 859 views
Massimo.Fiorentino
All of a sudden, variables are unavailable. The prototype works okay when, say, switching from light to dark mode, so the variables work as they should, but I cannot open the library and make changes. Does anybody have any hints?
Best answer by tank666
In your screenshot, you can see that you clicked on “Change variable mode”. But instead, you need to find the “Local variables” section (between the “Page” and “Local styles” sections), where you should have clicked “Open variables” (settings icon) or used the “Toggle variables” command in the Quick actions bar.
Please check out this Help Center article:
Figma Learn - Help Center
tank666
  • March 12, 2024
Massimo.Fiorentino
🤦 It’s so embarrassing, of course. I had problems selecting certain variables from that menu previously, and it had been a while since I worked with them at all, so I was too focused on that menu bar. Egad… Thanks.
