Issue with complex 'After Delay' > 'Navigate to' animations
  • March 13, 2023
  • 565 views
I’ve set up a placeholder for an incoming experience I haven’t kicked off dev for yet–and I know I’m pushing these animations out of scope–but I was wondering if anyone else has observed this?
What animations I’m using:
Interaction details: After delay (1600ms) > Navigate to > ‘Variant frame’
Animation: Dissolve, Gentle (3200ms) - *Smart animate causes issues with scroll
State management: Preserve scroll position (Yes)
Use case:
I essentially have (4) colorways for this experience, and I want them to gently cycle through on load.
What I’m seeing:
The issue is that when scrolling, the foreground elements (Text and vectors) jump when the dissolve ends at 3200ms.
Link to project - https://www.figma.com/file/D7rmZ7LRe11OOPVM4D10tZ/Personal-Website-%2B-Facilitate.Design-%2B-Williams-Made?node-id=144%3A65860&t=5dyB743vN582mwvU-1
(I couldn’t figure out a way to leverage components and variants for this, but I suspect this would happen in that instance too.)
I know this is an edge case but maybe there’s a way to fix this in the short run.
Cheers,
-a
