Hi, I’m remaking some components to take advantage of wrap in the hopes of only needing one component for desktop to mobile resizing, but im running into a bit of a problem with a kind of complex component, its easier to show you so please refer to the video
https://drive.google.com/file/d/1CeFQ4GpRFWbrdxdjMJ6LVsguD9BPtNcr/view?usp=sharing
I’m trying to get the image on the right side to shrink a certain amount, based on minimum width and minimum height constraints when the window / frame resizes so that the image gets slightly smaller before it finally break onto the bottom line in mobile view. I can either get the wrap component reflow correctly or I can get the image to resize, but no matter what I do i can’t get it to do both and I also cant get the image to retain aspect ratio, despite having aspect ratio locked…any advice or help would be appreciated.
