Icons only rendering sometimes
  • November 16, 2023
  • 257 views
Charlie_Brown1
I have components that are nested within other components to show certain icons depending on a card status. (example)
The problem is that around 50% of the time the icons are not showing within their status bubbles. The coloured bubbles will appear but no icon inside until each frame is clicked into, after that they will show up.
All layers are nested correctly within each other but is there some way to make the icons show consistently? Thank you
  • November 17, 2023
Hey Charlie!
Can you make sure that the layers are in the right order, and you didn’t click on the visibility icon of your component (to toggle the layer’s visibility off) in the layer panel?
More info in our help center article: https://help.figma.com/hc/en-us/articles/360041112614-Toggle-visibility-to-hide-layers
Would be great if you could share a quick video recording when the issue happens on your end and a copy of your file so we can also try to replicate the issue.
If you are hesitant to share the file, feel free to reach out directly to the support team here: https://help.figma.com/hc/en-us/requests/new
Hope this helps!
