When I export my frames to a pdf. it says that it exceeds the limit and when it gets exported, most of the content is missing. How do I fix this
  • April 15, 2024
  • 165 views
Chitraksh_Negi
Content missing when I export frames to pdf and the frames exceed limit
  • April 16, 2024
Hi there,
Sorry to hear this is happening! That definitely doesn’t sound expected. Can you please make sure first that those missing elements are nested inside the actual Frame you want to export? You can check this by viewing the layering panel on the left side of the screen.
If you are still experiencing issue after verifying the layers are nested to the Frame, please reach out directly to the support team here. Please include a link to the file and invite support-share@figma.com with “can edit” permission so we can look into this further. This will not count towards your billing at all. Thank you!
