How to remove a connected libarary?
  • April 2, 2024
  • 988 views
Ben_Marker
I copy and pasted a design system starter from the community. I have leftover color styles that I can’t find where they are connected. They are not listed in the library section under Assets, nor is it shown in the top right library icon. I deleted the initial design system working files…where are these coming from and how do I delete them? If I scroll to the bottom of the libraries section, the colors are not there, but there are swatches above, so I can’t right click them…??? How do I get rid of these?
Screenshot 2024-04-02 at 9.08.57 AM
Gayani_S
  • April 4, 2024
Hey @Ben_Marker, thank you for reaching out!
I am unsure if this will resolve your issue but could you try deleting colors from “Local variables”? You can navigate to the Design panel, where you will see the “Local variables” option at the top. Click this to remove the colors you wish.
If this doesn’t work, could you provide a direct link to the file here, and invite support-share@figma.com with “can edit” permission so I can look into this further? Note that users with @figma.com emails on your team do not count towards your billing.
If you’re unsure on how to invite someone to a file, please follow these steps:
  1. Click the “Share” button at the top-right corner of the Editor
  2. In the next window, type support-share@figma.com into the text box
  3. Select the “can edit” permission option
  4. Click the “Send invite” button
Thanks in advance!
