Comparing figma versions
  • January 11, 2024
  • 5 replies
  • 752 views
Nidhin_Kuttikkattu_Rajeevan
Hello experts…
Could I ask a question here. My company’s design team is releasing 4-5 Figma documents versions for design. Even though their release history says the changes, still there are hidden changes. I am planning to develop a plugin to compare 2 Figma documents. Is it possible to compare via plugin? Example we use a diff tool used for comparing 2 text document?
tank666
  • January 11, 2024
I have used REST API for my other works in python. So I know the concept. So here if I query a Figma document using REST API will it return the entire content and you suggest do that fetch for both files and do file comparison on the return result?
tank666
  • January 11, 2024
It depends on your ideas and needs. You can get JSON for the entire document or for a specific node.
Thank you Tank. I will try fetch this first and I will check what all things I am getting from it. Basically I want A-Z 🙂
