Library assets update
  • May 17, 2024
  • 4 replies
  • 352 views
Filip2
So i see this issue still persists.
When i change the component in my library that is a separate file and i publish changes, in my design files i can see that the component in assets panel shows the updated version but but not across my design layouts. And still I do not get the prompt window where i can review the updates and changes.
i have cleared the cache in my desktop app.
Any one has the same problem?
Thnx everyone
Filip2
  • May 17, 2024
ok, not sure of this is a new thing or a workaround but to make it all work as before, in my design file when i go to assets in dialog box header UPDATES tab appears. it recognizes the changes and gives an option to update changed/modified components across the whole file…
  • May 21, 2024
Hey there,
Thanks for reaching out. There was an update around Library update in March. After the change, when updates are available for a style, component, or variable on the current page, the Libraries icon in the top toolbar will display a blue badge. The popup windows doesn’t appear any more.
Figma Learn - Help Center
Library icon with blue dot
I hope this helps. Please let us know if you have any further questions!
Toku
Filip2
  • May 21, 2024
Thnx so much for the reply. Now i can see that. I do not get the UX of this at all but as long as it works that is great.
Thnak you once more.
Chris_Owemz
I have issues with updates not displaying in my file after updating it. It shows assets updated successfully, but it still doesn’t show. The updates come from a different file where I have my design system and where I create/update components for the file, and then I push to this new file.
This started today after the update to the side panels being restored to the edges.
Please help
