Using Variables to change component state
  • September 11, 2024
  • 1248 views
Fabio_Pia
I’m trying to set up a button so that it changes from a disabled to an active state when a certain condition is met. The condition is that at least two components (cards) need to be selected.
Currently, I’ve created two string variables: merge-button-state (with a default value of inactive) and card-state (with a default value of default). On each card, I’ve set an “on click” action to set card-state to “selected”, followed by the condition:
if card-state == "selected"
  set merge-button-state to "active"
This works if I select just one card, but I want the button to become active only when at least two cards are selected.
I’ve also tried creating a variable for each card component, like card1-state and card2-state, but since it’s the same component, this approach doesn’t work.
Any idea how to achieve that?
Raphael_M
  • September 12, 2024
