"Scroll To" from Variant 4 of a component
  • May 12, 2023
  • 788 views
Marlena_Capozzolo
Hi everyone! 👋🏾
I created a Component which has 4 Variants that appear by hovering.
In Variant 4 there’s an element (a button) to which I would like to apply the “Scroll to” function to make it scroll to a lower section of the page.
In order to do this, I momentarily set the instance used on my work page to the fourth variant, then I created the “Scroll to” interaction. But when I set the instance back to Default, the interaction doesn’t work. It only seems to work if I keep the instance on Variant 4.
I’d need the instance to be on Default and that only after hovering, thus passing to Variant 4 where the button actually is, the interaction is enabled.
Does anyone know how to help me? 😢
Thanks a lot! 💜
  • July 19, 2024
You’ll have to make a master component that is outside the variant group that has the “scroll to” interaction to get this to work.
