How can I add a gradient as variable in the new June 2023 update?
  • June 23, 2023
  • 12 replies
  • 9239 views
Ahmed_Dawoud
Before i can add create the gradients to use it as a tokens but after the new update I couldn’t m, there’s any way to do this?
Kenneth_Kammersgaard
I am pretty sure you cannot add gradients, it is only a single value in variables.
Ahmed_Dawoud
Hi, but my app primary branding color is a gradient. So it’s used a lot with different variations.
Yes, then I believe you have to keep using Styles. I am not sure, why they have introduced a color variable and not just using a string variable that could be used to set the color in a style. So there is not two different ways of handling colors. But there is probably a good reason 🙂
Ahmed_Dawoud
Thanks for your kind feedback. And I hope figma add this soon.
Mark_Kremer
I would like to have this functionality ASAP - allowing color variables to be gradients.
Corey_O_Brien
Same here. We use gradients all the time in our designs. Not having them as part of the variable system isn’t good.
Jane_Seneor
Yep we need gradients in variable too!
Armas_Nurbahari
Still no update for this?
Corey_O_Brien
  • Active Member
  • October 2, 2023
They added some other new things around scoping the variables recently but still haven’t completely fixed the variables to work with gradients and to work with type styles. 😦
Gyongy
  • October 18, 2023
Here is a solution using variables that mimics gradients: https://www.figma.com/community/file/1295349493892095561/gradients-with-variables
Corey_O_Brien
  • Active Member
  • November 2, 2023
Neat idea. Works well for a file with few gradients. Thanks for sharing.
Gyongy1
  • November 3, 2023
Thanks, Corey! I’m happy that it works fine for you. I appreciate the feedback! 🙂
