Urgent! Drop shadow disappears when font size increases
  • January 24, 2024
  • 4 replies
  • 285 views
I’m increasing the size of a design for a banner (8’ in size). I have to increase the font size on my banner to 480. However, the larger I make my font, then the drop shadow behind the text disappears. It seems to be related to the size - I tested out different font sizes and, as I increase the font size, the drop shadow gets smaller and smaller until it no longer shows. Does anyone know how to fix this? Please help as I need to get this banner ordered for an event - thanks!
  • January 25, 2024
Hi there,
I hope I’m not too late for your deadline.I’ve done some testing on my side and noticed the drop shadow is appearing.
Could you let me know if this issue occurs in the Figma desktop app, in the browser, or in both? Here’s a link to some basic troubleshooting tips that might help: https://help.figma.com/hc/en-us/articles/360040523973-Technical-troubleshooting-tips
If the problem persists, would you be able to share a link to the file and the text layers in question? I’d like to take a closer look to better understand what’s happening.
Toku
  • January 29, 2024
Hi Toku,
Thanks for your response. This is happening on both the desktop and web application. Here is the link to the page I’m working on: https://www.figma.com/file/e7SchILB1Hw7JhqOJo8RM0/Copy?type=design&node-id=5496-1508&mode=design
It’s the textbox that says “iNTELLIGENCE” that I’m struggling with.
Megan
  • February 13, 2024
Hi Toku - just wanted to follow up on this chain. Here is the link to the page I’m working on: https://www.figma.com/file/e7SchILB1Hw7JhqOJo8RM0/Copy?type=design&node-id=5496-1508&mode=design
It’s the textbox that says “iNTELLIGENCE” that I’m struggling with. Any ideas for why it works for you and not me? I talked to Support, and they said that the drop shadow should disappear if I make my font larger, but I don’t understand how you can successfully do it, but I can’t.
Megan
  • February 15, 2024
Hi @Megan15 ,
I apologize for the delayed response and thank you for providing the file link. I made a copy of your file and confirmed that the text does indeed have a drop shadow on my end. I also had one of my teammates check it, and they were able to see the shadow as well.
One potential explanation for this discrepancy might be due to the large file size. Please let me share the help center article:
Caution: Depending on your device and internet connection, files with a large number of blur effects can lead to reduced performance. Background blurs are typically the slowest effect to render.
To further troubleshoot, I separated the textbox into a separate file and confirmed that the shadow effect is still visible.
copied-copy.fig (21.0 KB)
Could you please check to see if the drop shadow is visible in this new file? If you have any teammates available, it might be helpful to have them check as well.
I hope this helps, and I’m here for any further questions you may have!
Toku
