Preserve Scroll Position is not working for a nav in auto layout
  • October 18, 2023
  • 4 replies
  • 392 views
I’m trying to preserve the scroll on a form. I have named the top layers as the same (apply now) which is what all the support I’ve read has said to do. The page that I want to preserve scroll also has an apply now frame but it is not a component. Any ideas? Thanks!
Best answer by Celine_
Hi Anna! Thank you for taking the time to share the details of your issue!
This looks odd 🤔 Can you also try to edit the top-level frame names with matching prefix to see if that helps? (Frame names have a common prefix, followed by a forward slash. For example, frames Checkout / Empty and Checkout / Complete match. )
Reminder: Top-level frames are frames placed directly on the canvas.
More information on Preserve scroll position in our Help Center article here: https://help.figma.com/hc/en-us/articles/360051747774#Rename_layers_in_bulk
If this doesn’t help, I would recommend you to contact our support team with a copy of your file so we can investigate it further here: https://help.figma.com/hc/en-us/requests/new
  • October 25, 2023
  • October 30, 2023
Do you know how to keep a top frame when the rest of the page is in auto layout? I’m struggling with that as the page needs auto layout for the footer to be pushed down as the accordion menu opens. If the whole frame isn’t in auto layout then the footer cuts off at the bottom.
Thanks
  • October 30, 2023
Thank you for your reply Anna! We will need more context to help troubleshoot and investigate further. Can you reach out to our support team and send a copy of your file and a quick video recording of current behaviour? Please fill out the form here: https://help.figma.com/hc/en-us/requests/new This will be the most helpful to better visualise and help you. Thank you for your understanding!
Laura72
  • October 31, 2024
Hi Celine and Annack,
I’ve been reading about preserve scroll position, and I have the same issue when my page is in an auto layout. I also have some open/close composent that pushed the components right under. When the page is just a frame, the interaction preserve the scroll position. But it doesn’t when I auto layout my page. And I have renamed and match all my frames as told in your articles.
Have you any tips for this ?
Thank you
