Unable to Access Plugins Despite Clicking "Plugins & Widgets"
  • September 24, 2024
  • 125 views
Muskan_Singh
Hi,
I’m experiencing an issue with the accessing plugins in Figma
Issue: Plugins not appearing when “Plugins & Widgets” is selected
Expected behavior: Plugins should appear for browsing and installation
Actual behavior: No plugins are visible.
Could you please investigate and provide guidance on resolving this problem?
Thank you for the attention to this matter
Best answer by djv
Thanks for the screenshot, @Muskan_Singh!
Sorry for the confusion, but only your already Saved plugins will appear here. This is not where to browse and Save plugins.
You can explore plugins and widgets from the community here: https://www.figma.com/community
When you find the plugin or widget you want, select Open in…
Choose whether you want to open it in a Recent or New file
Then, choose whether to Save the plugin to use later or Run the plugin to test it’s ability
After Saving, all of the plugins or widgets you’ve saved will appear from the toolbar
Hey @Muskan_Singh, sorry to hear this is happening!
I can’t seem to reproduce this behavior.
Is this happening both in browser or the desktop app? What OS are you using? Are you able to share a screenshot of what you’re seeing?
Muskan_Singh
  • September 25, 2024
Hi @dvaliao , it is happening in both browser and desktop app.
The OS which am using currently is Windows
