How to resize an instance and everything inside?
  • July 17, 2024
  • 218 views
Lilie_Pudnos
Hello! I’m very new to Figma and trying to just figure it out as I go. I’ve created an instance and I’m trying to make it thinner and have everything resize with it. How would I go about doing this? Is there something in the design panel that I’m missing?
If you could add visuals to your response, that would be great!
  • July 18, 2024
The contents should be set up correctly to scale as necessary. In this case the form and the fields inside it need to be set to Fill the auto layout frame.
