Bad Video Playback Quality
  • September 16, 2024
  • 16 replies
  • 2318 views
Tom_Birch
I’m using videos in my web prototype, however their previewing as crusty and pixellated.
The videos uploaded are small (6mb) and I’m currently not even using them fullscreen. Is there a setting that I have done wrong, or is there a work around?
  • September 23, 2024
Same here.
I understand the need for bandwidth and/or storage optimizations, but is there any way to increase video quality? Maybe by using local storage or preloading?
ksn
  • September 25, 2024
Hey both – I can’t be entirely sure, but this may be due to how we process video files in a prototype’s presentation mode at the moment.
In terms of things to try in order to improve the quality, see if the following steps below. @Tom_Birch this may not apply to you – I’m assuming you have a low resolution already, but just in case they may help you and @Jordi4:
  • Depending on how large the video will actually be in the prototype, you can reduce the resolution of the video which should help
  • In other words, if a 1920x1080 video will only ever appear in a frame that is 600 pixels wide, you can try to reduce the quality of the video to match the size of the frame it will appear in.
  • This means that Figma won’t try to compress the video as much, which might help with the quality that appears when this plays.
I realize that this probably affects the quality of what you’re trying to prototype, so I’m making sure to pass your feedback along internally. If you have any additional comments you’d like to provide, feel free to drop them here 😊
Josh_Nieten
  • October 8, 2024
I have a design concept that I have created that I want to put on my portfolio. It’s only a grand total of five pages. I am using Adobe Stock videos as background fills. Four out of the five work just fine! The fifth… no matter how much I try to encode it using Premiere, Handbrake, etc. … simply REFUSES to play without serious degradation. I’ve gotten this video to work at moments… only to quickly revert to the muddy, degraded version. There was one evening that I got it to play beautifully and crystal clear… then when the video looped it started alternating between gorgeous, crystal clear and completely muddled and pixelated. Every other time. I THOUGHT that I finally landed on a version (file size, encoding, etc.) that played gorgeously for one evening! Then the next day… 100% muddy and pixelated again.
I’ve tried SO MANY different things to get this single video to play beautifully like the other four!! The idea of EMBEDDING the video into my Figma design from my own hosting occurred to me just this evening. Sadly… it looks like Figma doesn’t support that. I’m honestly at my wits end trying to get this one video to play correctly while the others are playing just fine. I just don’t get it. PLEASE help!! 🙏
  • October 9, 2024
Thanks for the comment. It sounds strange that this happens only in a part of the file. I believe reaching out directly to the support team with a copy of your file would be best, so could you reach out at https://help.figma.com/hc/en-us/requests/new? Our support team can look into it.
Toku
Josh_Nieten
  • October 9, 2024
Thank you so much for your quick reply! I will reach out to them now! I appreciate it! ☺️
Ingchhorng_MRA
Not sure if it works for everybody, but in my case, i convert the video in webm format and found that it displays beautifully. Hope this helps! (I forgot to mention, this happened to me in Figma slide, the video has good quality but when inserted it became pixelated. So the file conversion works for me.)
  • November 26, 2024
Thanks for sharing the tip! It is helpful for others.
Sergey_Kisselev
Thanks for advice to compess to webm the video is more clean than .mp4, however the issue is still presist when droping file to Figma presenting mode, and video become pixelated again. 😦
weever22
  • December 11, 2024
Would love support here as well. Can’t seem to get anything to work in regards to showing video in high enough quality to not be pixelated.
Jim Jansen
  • March 27, 2025
Yeah I’m having the same problem. My showreel is absolutely butchered by Figma Slides, to the point where it’s unwatchable. What’s the point of a 100mb video limit if it still compresses everything down? And how can it be that professional software for creators like Figma gives no control over video compression? It makes it very hard to use.
Erwin_Otten
  • March 28, 2025
Yeah same problem here. Never had any problems with video quality before, but now Figma compresses everything to the point where the quality is gone. I’ve tried different ways to fix it (keeping the video under 10MB, using webm, mp4 with h264, h265, av1), but nothing works. These are short 1080p videos that used to look super sharp, but now they’re pixelated and low quality. It’s just looks awful.
Having the same problem as above. Videos are compressed and pixelated to the point where it becomes unusable as a design to present to a client.
Erwin_Otten
  • June 26, 2025
I've reported this issue (2 months ago), and Customer Support has confirmed it might be a bug:
Thank you for your patience.
Our engineering team has conducted a comprehensive investigation and confirmed that the problem you're facing is indeed related to a new bug. I am very sorry to let you know that at this time, unfortunately, we do not have an estimated timeline for a resolution.
I understand that this is not an ideal solution, but please know that we are actively working on improving our platform and addressing issues like this. We appreciate your understanding and patience as we strive to provide a better experience for our users.
As this issue is still under investigation, and since we are unable to keep tickets with customers open for a long period of time, I'm going to mark this ticket as closed while we wait for more information, but note this will not affect your ticket's status on the bug report. The bug report will continue to live internally and the engineers will troubleshoot further. If you have any follow-up questions or want to check on progress, just reply here and the conversation will re-open so we can give you a hand.
Thank you for your understanding.
Please let us know if you have any further questions before we close this ticket for the time being.
Again, we are very sorry that we are unable to provide a short term solution here.
Best regards,
... | Technical Quality Specialist
Erwin_Otten
  • October 2, 2025
I still haven’t found a solution for this issue. Any workarounds?
Roman_Polyakov
I have same question too.
Roman_Polyakov
In my case videos neither too compressed nor low res. Its 3668x2064 with 10 mps bitrate.
