Is there a way to quickly snap/trim frame to bottom most component?
  • May 3, 2023
  • 342 views
Arth_Addweb
The issue I am facing is that whenever I do adjustments in the design, Y axis of the footer is changed based on other components. Every time, I have to manually adjust the bottom of the frame to remove white space.
Is there any shortcut or any other method to trim the frame to the bottom-most element (Footer in this example) so that manual work is reduced?
Please find the example attached below for a better understanding of my query.
Thanks in advance 🙂
