Hi there. Wes here.
With the latest update (Figma Desktop App version 116.18.6 - On Mac) there appears to be an update whereby if you use the alignment tools, they now remain in an โactiveโ state with a blue stroke around each button.
This is causing quite an irritation for me as now as it stunts the flow of design as you now have to go back and manually select the same object again in order to manipulate its position.
This was so much better previously, please can you fix this. There is no reason why these alignment buttons need to remain active.
Thanks in advance,
Wes
