Variables not working on Instances
  • September 12, 2024
  • 135 views
Ruben_Mendoza
We have a component set with some variables. When using instances, we used to replaced the variables for new local variables. It worked fine, now it is not working properly. It tends to reuse the original one from the component.
I’m willing to share the file with Figma support. This is very serious issue as or design system heavily uses variables on components.
  • September 13, 2024
Hey there, thanks for flagging.
Could you submit a bug report detailing the steps that led to this issue? You can do so by following the link: https://help.figma.com/hc/en-us/articles/360041468234-Submit-a-bug-report
Thanks for your patience!
Denis_Wagner
yea I just discovered the same bug… annoying if you do advanced Design Kits for others to use (without edit rights in the main file)
please fix this Figma 🙂
