How to get rid of blank spaces while horizontal scrolling?
  • April 18, 2024
  • 7 replies
  • 1014 views
Anay_Mittal
So, basically I am making an OTT app design, where the elements are supposed to move horizontally, but after putting them in auto layout, setting their frame to same as that of og frame, and doing everything, im getting this weird blank spaces on both sides, tried padding aswell.
Please help, searched all over the net cant find the answer.
Figma – 8 Apr 24
Best answer by Vishal_Ramawat
Here’s the issue. You need to crop the image you are using as thumbnail (eg. G.O.T.)
Although it is masked, it is eating up/adding white space.
Just crop the images to thumbnail size and it will be fixed.
Vishal_Ramawat
Can you check why this frame #192 is oversized? This might be causing the issue.
Anay_Mittal
  • April 18, 2024
The issue still persists, it was unnecessary for me to keep them in auto layout tho, so got rid of the auto layout for “my list” text etc, but yeah, still the same issue
Anay_Mittal
  • April 18, 2024
in “only series expanded” frame, i made it so all text are first in auto layout then their below elements with them, still the same issue tho
Vishal_Ramawat
Anay_Mittal
  • April 18, 2024
YO! It actually worked!
Thank you so much!
prashant_sethi
I am not using a rectangle with no image, but I am still getting 40px space at the start and end of the widget.
portfelio
  • January 16, 2025
A solution is to ensure the objects you are trying to scroll within a scroll enabled frame all have clip content enabled.
