Using open overlay along with Component
  • May 20, 2024
  • 255 views
Ilia1
hi guys
I’m doing a project and it has a chart in it
i want certain points in this chart to be highlighted when hovered over and at same time show an overlay while doing this
i managed to achieve this by adding two actions to the hover interaction
but my problem is that when i stop hovering over this point
the overlay wont close
i even tried to use move in move out interactions
but they wont work either
here is the link to the chart i made , i used both hovering and move in move out methods , i would appreciate any help or suggestion , hovering works but when i stop hovering over it , it wont change back to normal , unless i click somewhere else
i have 3 points on my graph that i marked so you wont have to spend extra time understanding my problem
Figma – 20 May 24
Vishal_Ramawat
It’s difficult to add multiple hover interactions. You can check out the discussion here and check out the YouTube Tutorial that will be helpful for this.
