[Prototytping] Responsive mode doesn't stay centered
  • October 25, 2024
  • 73 views
Gabriel_Cecchi
Hi everyone !
I hope everybody’s well.
Here’s my subject :
i’m working on a “bento design” and i have an issue with my prototype : when i play it for the first time, the navigation keep resizing the screen in the top left corner before getting back to normal (which make the experience nauseous and feeling bugged). BUT once he did this little glitch everything works fine.
to give you a bit more info,
i’m using a component and 2 interactions in this order :
  • Change to > changing the dot
  • Navigate to > to change the content of screen
And the 1st frame inside the main ones :
  • are always named the same
  • are in fill with a min and max width
  • i used exactly the same method for the menu and it’s working just fine
I tried to change the order but it doesn’t help and it just delete my dot animation… Anyone already had this problem ? Anyway to fix it ?
Thank you all !
Have a nice day
