Copy / Paste of Properties does not work anymore for vectors
  • June 30, 2023
  • 9 replies
  • 1147 views
Mathias_Temmen
Today I noticed that copy / paste of properties does not seem to work properly anymore for me.
Whenever I try to Option-CMD-C stroke properties from a vector, it shows no effect on the other vector item after pasting it using Option-CMD-V.
However it works with closed paths sometimes and fills are no problem at all.
Works:
  • Fills
  • Rectangle to rectangle strokes
  • Rectangle to ellipse strokes
  • Rectangle to line
Does not work anymore:
  • Ellipse to ellipse strokes (???)
  • Line to line
  • Vector to vector
This is blasting my workflow right now. Did anyone have the same experience?
Mathias_Temmen
  • June 30, 2023
PS: I am working a German keyboard but changing to English (US) didn’t help either.
Mathias_Temmen
  • June 30, 2023
Sorry for spam. I am running macOS Ventura 13.4.1 and Figma App version 116.10.9
Edit: MacBook Pro M2 Max
Petar2
  • June 30, 2023
Literally have the same issue since the last 2 hours. I use different keyboards, restarted the app and browser but nothing helps
Isaac_VanDyne
Also experiencing this! Super frustrating for my icon design workflow. please fix asap
Isaac_VanDyne
Also noticing that for the shapes that style copy/paste does still work on, it often detaches the style and pastes the color as a raw hex code.
Ryan_52
  • Technical Quality Specialist
  • June 30, 2023
Thank you for your patience while our engineers worked on resolving the issue you reported. We are pleased to inform you that the fix has been successfully released!
Please refresh Figma to ensure that you are using the fixed version.
Mathias_Temmen
  • July 3, 2023
Thank you for the fix 🙂
Jarrett_Inge_INFOSYS_LIMITED
This seems to be broken again. same issues as posted before. NVM, false alarm, it started working after i updated the app.
EMMANUEL JOHN
Hello guys, there is still an issue with the copy and paste on the web version. Only paste text in a situation where you copy a frame or component. if you are copying vectors or images, it does not paste at all. This is really frustrating.
