Hi, Create component set option is missing in newer figma updated version
  • August 1, 2024
  • 238 views
Hi, i am a Figma Designer, Create component set option is missing in newer Figma updated version, please could you fix that problem ?
Manju1
  • August 6, 2024
select Design in right side tool bar → Above position you see frames, dev symbol, create component symbol, union selection symbol and three dot (more option) → click that three dot you can see the create component set
