Library syncing issues
  • June 4, 2024
  • 4 replies
  • 341 views
Mike_Cho
Hi everyone,
I have a design system library that I publish regularly. This library is being used in other project files. Recently I noticed that whenever I publish an update to the design system library I encounter the following three scenarios:
  1. The project files using the design system library is correctly receiving notice of all updates. I click “Update all” and it successfully reflects all changes.
  2. The project is correctly receiving notice of all updates, but clicking the “update all” button won’t reflect the updates. So, no changes at all. The “update all” button remains.
  3. Not receiving notice of the updates at all.
What I tried
I have read other threads in this forum, where some users suggest to repair various connections, which I did to no avail (also, the same design system library was successfully published and updated before).
My questions
Is this a bug? Is this a traffic bandwidth limitation? Is there a methodology that I’m not aware of that prevents this from happening?
Edit
One thing to note is, that closing the app and not starting it up for a few minutes, sometimes resolves this problem, which could point to a memory/cache issue. Either way, I don’t think this issue is ok to pass on as it makes Figma less reliable to work with.
Thank you to whoever finds the time and energy to respond.
Have a good one.
janoca
  • June 4, 2024
The same issue has been happening with me since last year and they haven’t fixed it yet. It happens quite often when I edit a component inside our design syste, then I update the same component inside a file, nothing happens or I have to reset the entire component to see the changes, loosing all edits I’ve made. It’s really annoying and I wish Figma would give more attention to it.
Christian_Davis3
Yea I am having this issue too. Sometimes it self resolves, but Figma needs to work out this bug. I make changes DS, update, go to the file instance, update shows, I click update, but updates are not reflected.
Kai Smith
  • March 17, 2025
Adding weight to this problem.
Any response from Figma.
thanks,
  • March 19, 2025
Hi ​@Kai Smith
If you don’t see any visual updates, could you try “Regenerate all instances (slow)” via Actions menu?
If the issue persists, it could vary depending on your files, so could you reach out directly to the support team with a copy of your file: https://help.figma.com/hc/en-us/requests/new? Our support team will look into it.
Please make sure you use the email associated with your Figma account, include links to the file in question, and share access with support-share@figma.com. Don't worry, inviting us to view your file won't impact your billing.
Thanks!
Toku
