VERY advanced Scroll challenge
  • April 19, 2024
  • 8 replies
  • 452 views
Koen_van_Niekerk2
Hello Figmators.
I searched the community but could not find an answer.
I need to build (prototype) a bi-directional scroll with both a fixed column and a fixed row. I tried a lot, but did not manage it.
The only way I can explain it clearly is with a movie (see below). Does anyone know how to build this?
thanks!
Koen
  • Figmate
  • 2624 replies
  • April 22, 2024
Hi @Koen_van_Niekerk2, Thanks so much for reaching out about the prototype challenge! Our community is always here to lend a hand where we can!
From your description, it sounds like something related to apply scroll overflow in both directions (horizontal and vertical) to a frame. But I’m not sure.
Also, we’re having some trouble playing the video you shared. Could you kindly re-share it with us? We’d love to understand the specifics of what you’re trying to accomplish.
We’re looking forward to hearing back from you soon! And of course, if anyone from our community has insights or suggestions, don’t hesitate to jump in!
Koen_van_Niekerk2
  • 11 replies
  • April 22, 2024
Hi @Junko3 .
Thanks for your quick response. What I am looking for is more than regular Scrolling in both directions. It is hard to explain without the movie. It is a quick time movie. Can you indicate in what format I should upload (or link to) the movie for you to see it?
thanks!
Koen
Vishal_Ramawat
Here is the link to video: https://www.dropbox.com/scl/fi/o919ohjk6nbsvv0zx2h1k/DoubleScroll_FreezeRowAndColumn.mov?rlkey=simng6bqow90cbusyouupk5tq&e=1&st=yyg11qc6&dl=0
What Koen is trying to achieve is Freeze Pane like in Excel.
Lemme try this and get back to you guys!
Vishal_Ramawat
Ok, so I did this:
1st Column with n Rows, no scrolling
2nd Column with nxn table, horizontal scrolling
Grouped these in single frame, vertical scrolling
Now the issue is, when I hover on Column 2, horizontal scrolling works, but not vertical.
And on 1st column, vertical works but not horizontal.
So, I have move cursor to specific ‘side’ to make scrolling work.
Sometimes, it does work in both ways if my cursor is on White grid lines in column2. Weird.
Koen_van_Niekerk2
  • 11 replies
  • April 23, 2024
Hi Vishal,
Thanks for taking up the challenge!
If you think you may have (the beginning of) a solution, could you post a link to your file, to see how you solved it?
regards,
Koen
Vishal_Ramawat
Here you go.
I guess, I am using trackpad so scrolling is sensitive, but it does work somewhat.
Figma – 24 Apr 24
Koen_van_Niekerk2
  • 11 replies
  • April 24, 2024
Hi Vishal
Thanks for sharing. I checked out your solution and used it to try to indicate what it is I am aiming at (see image)
Vishal_Ramawat
Well, I’ve spent quite a time on this and seems it isn’t possible using out-of-the-box features.
I just ended up creating a workaround for ‘demo’ purpose.
Created 2 Variants of the table and switched the scrolling by clicking on Header or 1st Column.
So if you want to make Column sticky, click on the column, if Header, click on Header.
It starts with sticky column.
I know it isn’t what might be intended behavior, but hope some other member might help out.
I have updated my Figma file. Do check it out!
