Can't find sections to take notes -- Fogma Slides
  • June 27, 2024
  • 104 views
I did not see the section to take notes in the Figma Slides. How to put it out? Thanks
ksn
  • June 28, 2024
Hey @Jingyi_Ma! You can add presenter notes by following these instructions:
  1. Open your slide deck.
  2. Use the toggle in the left sidebar to switch to Slide view.
  3. Select the slide you want to add presenter notes to.
  4. Type your notes in the field that displays below the slide (there’s a small white line below the slide – if you hover over it, you’ll see ‘show presenter notes’)
You can also format your notes to fit your needs – see this page for details 😊
Chris_P1
  • November 20, 2024
It would be great if this was available any time a slide was selected and we weren’t forced to jump back and forth into single slide view…
Seem like a slide should have notes… period.
How great would it be to have the notes be toggleable as element boxes below the rows of slides? Being able to see the BIG PICTURE all at once is what tools like FigJam is all about, right?
So being able to see the “Whole Story” without having to click through slides one by one, would be a great addition in my opinion.
