Instance breaks autolayout wrap after changing to another variant
  • January 15, 2024
  • 212 views
CamilaB
File for reference: https://www.figma.com/file/v9PuyvEWCmWZ631e3KpWo5/Error?type=design&node-id=0%3A1&mode=design&t=3uOJJX0KDqEZ405s-1
I created a dialog box that uses a nested component called “footer” where I added two instances of the button component.
The buttons have a minimum size, as the footer is supposed to wrap if the container gets too small.
The component works fine, until I change one of the button variants. I have a variant called “Error” for one of the buttons (don’t come after me with variables, it doesn’t allow for enough modes to use it for button states). When I change the button variant, it breaks the wrap and both buttons are smushed together in a single row. I can get them to wrap again but only if I change them to “hug”, but I need them to fill each of their lines.
Raphael_M
  • January 16, 2024
Hi, CamilaB. It seems to work fine with me when I detached the instance and use the _Dialog/Footer component you created in the file. Have you checked the original Dialog component or the nested _Dialog/Footer you put originally in the original Dialog component? I’m not entirely sure if this is a bug or not.
CamilaB
  • Active Member
  • January 16, 2024
Hi Raphael, thanks for testing. I have added the minimum width for the buttons in the _Dialog/Footer component and it seems to be ignored whenever I change the button variant. You are correct, it seems to work correctly when I detach the parent component (Dialog), it fixes it automatically even. I don’t believe this is the expected behaviour. I avoid detaching my components, so it would be best (in my case, at least) that it acted the same.
Raphael_M
  • January 17, 2024
Hi, Camila. I’m not entirely sure regarding this. You may check with the Figma mods to see if they can help. For me, I think this is a bug.
