Bug: Text style overrides inherited from shared styles are impossible to read
  • July 8, 2024
  • 93 views
Emery_De_Nuccio
There is no possible way to read text styles that are inherited from a style override in at least some cases.
Please see this example:
Figma – 5 Jul 24
The output we receive from v1/files/:key is the following:
  "id": "1:2",
  "name": "Frame 1",
  "type": "FRAME",
  "scrollBehavior": "SCROLLS",
  "blendMode": "PASS_THROUGH",
  "children": [
      "id": "1:6",
      "name": "This is not working",
      "type": "TEXT",
      "absoluteBoundingBox": {
        "x": -43,
        "y": 146,
        "width": 377,
        "height": 51
      "absoluteRenderBounds": {
        "x": -40.58975601196289,
        "y": 155.5,
        "width": 370.986328125,
        "height": 40.56817626953125
      "constraints": {
        "vertical": "TOP",
        "horizontal": "LEFT"
      "relativeTransform": [
          1,
          0,
          247
          0,
          1,
          405
      "size": {
        "x": 377,
        "y": 51
      "fills": [
          "blendMode": "NORMAL",
          "type": "SOLID",
          "color": {
            "r": 0,
            "g": 0,
            "b": 0,
            "a": 1
      "fillGeometry": [],
      "strokes": [],
      "strokeWeight": 1,
      "strokeAlign": "OUTSIDE",
      "strokeGeometry": [],
      "exportSettings": [],
      "effects": [],
      "characters": "This is not working",
      "style": {
        "fontFamily": "Inter",
        "fontPostScriptName": null,
        "fontWeight": 400,
        "paragraphSpacing": 20,
        "textAutoResize": "WIDTH_AND_HEIGHT",
        "fontSize": 42,
        "textAlignHorizontal": "CENTER",
        "textAlignVertical": "TOP",
        "letterSpacing": 0,
        "lineHeightPx": 50.82954406738281,
        "lineHeightPercent": 100,
        "lineHeightUnit": "INTRINSIC_%"
      "layoutVersion": 4,
      "characterStyleOverrides": [
        0,
        0,
        0,
        0,
        0,
        0,
        0,
        0,
        22,
        22,
        22
      "styleOverrideTable": {
        "22": {
          "fontWeight": 400,
          "fontSize": 42,
          "letterSpacing": 0,
          "lineHeightUnit": "INTRINSIC_%",
          "inheritTextStyleId": "1:7"
      "styles": {
        "text": "1:7"
      "lineTypes": [
        "NONE"
      "lineIndentations": [
        0
It has no indication of the bolded “not” text.
Another thread on here indicated that one could possibly read the styles themselves with v1/files/:key/nodes?id=1:7
but that returns equally useless data:
{"name":"Untitled","lastModified":"2024-07-08T04:57:09Z","thumbnailUrl":"https://s3-alpha.figma.com/thumbnails/6d10bb51-26f0-4325-bb71-8ff35b328552?X-Amz-Algorithm=AWS4-HMAC-SHA256&X-Amz-Credential=AKIAQ4GOSFWCR2CQHY4J%2F20240707%2Fus-west-2%2Fs3%2Faws4_request&X-Amz-Date=20240707T120000Z&X-Amz-Expires=604800&X-Amz-SignedHeaders=host&X-Amz-Signature=1b8448c61c015792e4c6e15f6fd2ca09056e93470a44b1af7cbd92e087c0eec8","version":"6160118581","role":"owner","editorType":"figma","linkAccess":"view","nodes":{"1:7":{"document":{"id":"1:7","name":"TestTextStyle","type":"TEXT","scrollBehavior":"SCROLLS","blendMode":"PASS_THROUGH","absoluteBoundingBox":{"x":0,"y":0,"width":160,"height":51},"absoluteRenderBounds":{"x":3.698863983154297,"y":10.036930084228516,"width":152.99574279785156,"height":40.03125},"constraints":{"vertical":"TOP","horizontal":"LEFT"},"fills":[{"blendMode":"NORMAL","type":"SOLID","color":{"r":0,"g":0,"b":0,"a":1}}],"strokes":[],"strokeWeight":0,"strokeAlign":"INSIDE","exportSettings":[],"effects":[],"characters":"Rag 123","style":{"fontFamily":"Inter","fontPostScriptName":null,"fontWeight":400,"paragraphSpacing":20,"textAutoResize":"WIDTH_AND_HEIGHT","fontSize":42,"textAlignHorizontal":"LEFT","textAlignVertical":"TOP","letterSpacing":0,"lineHeightPx":50.82954406738281,"lineHeightPercent":100,"lineHeightUnit":"INTRINSIC_%"},"layoutVersion":4,"characterStyleOverrides":[],"styleOverrideTable":{},"lineTypes":["NONE"],"lineIndentations":[0]},"components":{},"componentSets":{},"schemaVersion":0,"styles":{}}}}
The bold text is still nowhere to be found indicated anywhere and impossible to know.
Can we please get an ETA on a fix on this? The previous issue we reported has gone unaddressed for over 2 weeks now.
  • July 23, 2024
Hi there! Thank you for flagging this and taking the time to report!
I can see on our backend that our engineering team is still investigating this issue.
To give some visibility here for the community, while this issue is still under investigation, this bug might not have an immediate resolution at the moment. Due to its complexity and other priorities, it could take some time before we can address it.
While we can’t promise a quick fix, rest assured that our engineering team is aware of the issue and will work towards finding a solution in the future. We appreciate your understanding and for your patience while the team continues investigating 🙏
