Overflow components
  • March 19, 2024
  • 339 views
Ewa_Bak
I need help in building components like in this example from Carbon Design System UI Kit:
Meaning that part of the component is clickable and its dropdown is “unselected”. I know I can “trim” a component by changing its size while holding command button but it is not that, as you can see in the screen that this square button has “hug” properties.
  • March 21, 2024
Hi there,
Thanks for the post. Just to clarify, would you like to have two states of the button? If that’s the case, I think you can utilize Variants in Components.
Variants allow you to group and organize similar components into a single container. You can learn more:
Figma Learn - Help Center
I’m not 100% sure what you’d like to achieve, so please feel free to let me know, if I may be misunderstanding the points!
Toku
