Resize Text: long text does not stretch in Autolayout
  • September 13, 2023
  • 967 views
Ayako
Hi I’m Aya, beginner.
I tried to make an example from Figma education.
I can not resize text box.
The yellow one is what I want. The text stretch when you make the box wider.
But mine (red one) 's text stay the same. when I make it narrower , it works fine.
The setting looks the same as example.
What am I missing?
Thanks in advance for your help!
Figma – 13 Sep 23
Best answer by IraX
Its width is already set to Fill, but there are line breaks in the text, forcing what seems to be a fixed width, but isn’t. Remove the line breaks so the text flows.
IraX
Ayako
Thank you so much! I could fix it:)
