How do I border a shape in FigJam?
  • March 23, 2023
  • 15 replies
  • 17016 views
How do I add a border to a shape? Or Change the colour of the border on a shape? (NOT an image)
Best answer by Haroll
Oh my bad, I read to quick @Franco5
You can add/change/remove the line (which is different than a border) of a shape on Figjam by clicking on your shape and then selecting Line style option (as shown bellow). Other than that you won’t be able to do anything else (cannot choose its width nor its color)
Haroll
  • Active Member
  • March 23, 2023
Hi @Franco5
If you want to add a border to anything in Figma, take a look at your right panel and you should see a category called stroke, click on the plus (as show in the image bellow)
and a border will appear on your shape. You will then be able to play with its color, size and style
You can read more about stroke here
Figma Help Center
Let me know if it helps
  • March 23, 2023
Hi specifically figjam not figma
Figma
Haroll
  • Active Member
  • March 23, 2023
Cid_JIANG
  • July 20, 2023
hi, guys, off course u can modify all style,what u need to do is,open the design file(blue one),and style any elements,eg. press shift + s, u have a section, now, we can add more boder width~ then copy it to FigJam~
HOW ABOUT NOW ?!BABY~ :)
  • August 3, 2023
This isn’t the solution, you didn’t answer his question.
It seems you CANNOT add a border directly onto an image in FigJam. You must draw a shape around it and add the border to that shape.
  • December 13, 2023
Is it possible to change the border’s color?
I can’t find a way to do so in FigJam. 🤔
  • December 13, 2023
Hey there,
No. It’s not possible to change the border color in FigJam.
Yosafat_kesuma
Have you try make the component at Figma first, and then copy the component to FigJam?
I’d really like this feature. Seems pretty basic to be able to set the color of the outline, instead of accepting the default gray color.
Leslie_Tou
Mind blown haha
Diana_Fernandez
I’d like to choose another width for the borderline 😦
Cameron7
  • January 30, 2024
Please add changing border color, thanks!
MichelleBarnes
To add a border color:
Line style, select “Solid”.
Shape fill color, select “no fill”.
Then go back to shape fill color and select the color you want.
The color will only affect the border.
Hope this helps!
This works!! Thank you so much!
Mahbub
  • October 27, 2024
You can follow this video tutorial to add shape border and change border color in FigJam: https://youtu.be/PELM17xyawk
