Material 3 Design kit doesn't update the style
  • September 4, 2023
  • 888 views
murilocontro
Hi guys, it is my first topic here and I am also not so familiar with Figma, so go easy 🙂
I am using Material Design from Google and I changed the primary colors. When I add an asset from Material Design in a new file this component does not come with the colors I applied before. Why? I checked the original file and it is fine there. Also, my team’s library is set to use Material Design… What I am missing?
Thank you in advance for any help…
Cat8
  • May 11, 2024
Did you export all material design components as a library and then reimport them into your project?
