Two interactions of the same trigger problem
  • May 6, 2023
  • 294 views
So, I needed to add an icon button that changes its color while hovering and at the same time opens an overlay, but It seems that Figma doesn’t allow two interactions of the same trigger. So, I tried to open the overlay using “Mouse enter” trigger while keeping the change to connected to “While hovering” trigger, but the same problem happened and the mouse enter property canceled the “while hovering” interaction.
Does anyone know why is that happening? Am I doing something wrong?
Gayani_S
  • May 11, 2023
Hi Ebrahim, I have a workaround for this. Try to create a component with a hover interaction for the icon button. And then you can use this component and make an overlay with hover interaction.
Hope this helps!
