Can't copy component description
  • May 6, 2024
  • 6 replies
  • 302 views
Tiger_ShenTai
I wrote down the code into the component description area. I can double click to select the description at the Dev mode, others can easily copy and paste to their project. but now. Can’t select anymore. and allow set the description content to code. But why remove the select function.
ksn
  • May 7, 2024
Hey @Tiger_ShenTai - sorry for the trouble, but could you post a screen recording of what you’re seeing? I wasn’t sure if I understood your post correctly, and want to make sure I address the correct problem.
Tiger_ShenTai
Thanks for your attention. 🥹 🥹
Sry, hard to upload video, cause the size limited. Let me explain with screen shot
Step 1 : i wrote down the code at the component description area. and set the content as code.
Step 2: I change to Dev mode. check the code if it can be copy or not. The result is can’t. But, just few weeks ago I can copy at the Dev mode. We can set the content as code, But can’t copy, it’s weird. The code is for help developer to copy easily. but now can’t copy anymore.
Stan5
  • May 10, 2024
Sounds like you should rather use Code Snippets for that: Code Snippet Editor | Figma
Tiger_ShenTai
Thanks a lot 🙏 🙏 @Stan5 , but this is a plugin, there have so many developers need to know this plugin and how it works, it will cost resource. and the description of component already support set content as code mode. it will be better than the plugin. 🤔 🤔
Stan5
  • May 19, 2024
The developers won’t have to play with the plugin. They’ll just see the code snippet in the dev mode panel. The main advantage is that the code will be dynamically generated based on the instance’s props.
As you said it definitely adds a bit of workload for the design system maintainer.
Tiger_ShenTai
Let me try this plugin first. thanks dude.
